Getting currency code for a security
When I request the currency of a RIC like DTEGn.DE using the Eikon Data API using Python (streaming MarketPrice domain), I don't get back the ISO code (EUR) but a number (978). How can I translate this into the ISO currency code string?
Similar problems are found with other fields, e.g. CF_EXCHNG for the name of the exchange the security is traded on.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonforexstreaming-prices
3.8k 4 4 6
Hi @GoGoGroundhog
The logic of enumerated values you find in the enumtype.def file that can be located in the default Thomson Reuters Eikon location:
\AppData\Local\Thomson Reuters\Eikon User\Cache\UUID\PersistentFiles\Config\RealTime
Thanks. How can I programmatically derive the UUID to be included in the above path?
@GoGoGroundhog
Try this:
from winreg import *
import xml.etree.ElementTree as ET
registry = ConnectRegistry(None, HKEY_CURRENT_USER)
rawkey = OpenKey(registry, r"Software\Thomson Reuters\DumpUploader")
val = QueryValueEx(RawKey, "FilePath")[0]
root1 = ET.parse(val.split("LibraryCache")[0] + "LMO.LatestUserAccount.xml").getroot()
enumtype = val.split("LibraryCache")[0] + (root1.attrib['uuid'] + r"\PersistentFiles\Config\RealTime\Display Templates" + r"\enumtype.def")
Thanks, works fine.
