When i run the project starter consumer after changing the config file, i get this error.
Config changes :
\appId = "ELEKTRON_DD"
\enumDictionaryFilename = "./enumtype.def"
\fieldDictionaryFilename = "./RDMFieldDictionary"
# position to be used for Login
# According to the RDM usage guide: If the server is authenticating with DACS, the consumer application might be required to pass in a valid position.
# ip addr/hostname or ip addr/net
# \position = "MyHostNameWasAddedHer"
\runTimeInSeconds = 0
\service = "DIRECT_FEED"
\session = "Session1"
\userName = "MyUserNameWasAddedHer"
\itemName = "TRI.N"
