Re: tag 789 NextExpectedMsgSeqnum / Quickfix C++
Is there a patch for any of the QF C++ version with support of tag 789?
I can see it referred on sourceforge, but can't find it on RDC.
https://sourceforge.net/p/quickfix/mailman/message/34163573/
elektron-sdktreprfarfa-api
7.6k 15 6 9
@vzaytsev
MAPI or Matching API has its own support group. You have to contact the team via the following page
https://transactions.thomsonreuters.com
7.6k 15 6 9
@vzaytsev
Not sure about Refinitiv's API you currently use and why you post the question on our Dev Portal.
As far as I understand QuickFix is not our API product. It seems to be API provided by the external community. I would suggest you contact the API owner on SourceForge or GitHub directly if you want the patch.
I'm using MAPI/RFA. I know that the quickfix is not your product, but there was a reference that MAPI docs should have reference for a patch for quickfix c++. I'm looking for that patch here and can't find it.
MAPI samples for java show use of quickfix/j. So Reuters is leaning on the use of quickfix.
The question is simple - is there such patch with support for NextExpectedMsgSeqnum for quickfix c++ ?
Thanks,
Vladimir
