Why doesn't Application.Run("RtGet","IDN",RIC,FID) work in Eikon for Excel VBA?
eikoneikon-com-apiexcelvbart-get
In 3000Xtra/PowerPlus Pro, it was possible to call individual items of data using VBA's Application.Run, where worksheet functions can be called - as RtGet is a worksheet function data could be called, for example;
Sub myRtGet()
     Dim myRtGetVal As Variant
     myRtGetVal=Application.Run("RtGet","IDN","EUR=","BID")
     Do Until myRtGetVal<>"#NA NA"
          Doevents
     Loop
     MsgBox myRtGetVal
End Sub
In Eikon for Excel this code (which has to look for the "Retrieving..." value to change, i.e. Do Until myRtGetVal<>"Retrieving...") will keep looping and will continue to return "Retrieving...". This is a result of the way that Eikon for Excel works with Microsoft's RTD (Real Time Data). By looping with the Application.RTD.RefreshData method, the data will be returned.
Sub myRtGet()
    myRtGetVal = Application.Run("RtGet", "IDN", "EUR=", "BID")
    Do Until myRtGetVal <> "Retrieving..."
        DoEvents
    Loop
    MsgBox myRtGetVal
End Sub 'NOTE - This only works with RtGet(). Using the method with RData() or RHistory(), the "Updated at hh:mm:ss" value will be returned.
