Error using eikonapir - it stalled and never received data
I followed this
install.packages("devtools")
library(devtools)
install_github("ahmedmohamedali/eikonapir")
library(eikonapir)
eikonapir::set_proxy_port(9000L)
eikonapir::set_app_id('Your App Key Here')
result <- get_symbology(list("MSFT.O", "GOOG.O", "IBM.N"),"RIC",list("ISIN"),raw_ouput = FALSE,debug=FALSE)
print(result)
but when i ran the following codes,
eikonapir::set_app_id('xxxxxxx')
The "get_symbology" lines ran for a long time. I waited 30mins then had to manually stop it. when i stopped it, i get this error.
“Error in curl::curl_fetch_memory(url, handle = handle) :”
“Operation was aborted by an application callback”
any idea why?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythoneikon-api-r
18k 21 12 20
Hi @cameron2028
I think you should confirm the Eikon R API usage with the contributor on Github.
