Elektron SDK C++ tutorial example - Unable to login
I am currently trying the tutorial example for contributing data "Elektron Message API - Consumer Tutorial - Posting data to TR Contribution Channel" on a Windows 10 machine.
The following line seems to timeout:
OmmConsumer consumer(OmmConsumerConfig().host("ecc01-emea1.fr.aws.thomsonreuters.com:443").username("GE-A-01281282-3-2411"));
And I get the following error:
Exception Type='OmmInvalidUsageException', Text='login failed (timed out after waiting 45000 milliseconds) for ecc01-emea1.fr.aws.thomsonreuters.com:443)', ErrorCode='-4052'
I believe the server and port are correct and the username is the one I received.
Any ideas?
elektronrefinitiv-realtimeelektron-sdk
For Windows, EMA needs to have an encrypted protocol type set to SOCKET. Please see the Channel_3 configuration in EmaConfig.xml provided in Cpp-C/Ema/Examples.
The line is:
<EncryptedProtocolType value="EncryptedProtocolType::RSSL_SOCKET"/>
This encryption type requires OpenSSL libraries, which are not built by the Elektron SDK package. Please see chapter 4.3.3: Encrypted Connections in the EMA Developer's Guide for more information.
This functionality was added in 3.3.0, which was released in March 2019.
Thank you for pointing this out. It is working now.
Hi @emir.subasic
The above host value is a valid TRCC mount point and should be working fine.
Just want to check you are following all the steps in the tutorial - including changing the Channel Type to RSSL_ENCRYPTED from the default RSSL_SOCKET
Rather than hard coding the host:port into the source code, change the config file as described in the tutorial for now and confirm it all works.
Below is a screenshot that illustrates the usage and the error I am getting. As you can see the xml is updated for Channel 1 and 2. It is in the same directory as the source. When run it is somehow still picking up localhost.
I guess that's the default when not specified:
OmmConsumerConfig& host( const EmaString& host = "localhost:14002" );
See error below.
Any ideas on whats wrong? Thanks
Have you had a chance to review my last post please. This is quite an urgent issue for us.
Hi @emir.subasic
The EmaConfig.xml files needs to be in the Working Directory which defaults to the location where the Project files etc are located i.e. $(ProjectDir)
For example, on my PC I placed the EmaConfig.xml file in
C:\Code\ESDKC131VS2017\Cpp-C\Ema\Examples\Training\Consumer\300_Series\341__MarketPrice__OffStreamPost
where C:\Code\ESDKC131VS2017 is the location of my main esdk.sln file.
If you copy the file to that location, it should pick up the contents of the file.
Thanks for looking into this. I have tried that but now get a different error.
I provide my EmaConfig.xml and the latest log file. Please note I had to rename the files extension to txt in order to upload here.
emaLog_16628.log.txtEmaConfig.xml.txt
emalog-16628log.txt (18.7 KiB)
emaconfigxml.txt (18.0 KiB)
