We I try to get news using dataplatform function get_news_headlines I get None.
rdp-apirefinitiv-data-platformnews
Could you please elaborate your question. Are you using the online API docs, or using your own application, or using the RDP libraries to get news. What is the message that you get back from the platform. Does your ID have permissions to get news headlines?
If you are starting out with RDP, I would recommend that you take a look at RDP libraries, since it has easy to use content and delivery layer, for news - https://developers.refinitiv.com/refinitiv-data-platform/refinitiv-data-platform-libraries/quick-start?content=55663&type=quick_start
We use RDP libraries . we get None as response.
Which language and what is your news query? Have you tried getting news headlines directly at online portal @ https://apidocs.edp.thomsonreuters.com/Apps/ApiDocs?
11.5k 16 7 10
Hello @kamal.chancari
Could you please also share your News Query and parameters that you pass into the rdp.get_news_headlines function?
