Getting an exception when running through executable jar. working fine when running on IDE.
Thanks in advance!
Thanks in advance!
Hello @bmahajan
It seemed that you did not include EMA Jar file so you got java.lang.NoClassDefFoundError: com/thomsonreuters/ema/access/OmmException. You can set up build environment as outlined in the ESDK Build System. Then, you can start EMA Quick Start to consume data.
Hi @bmahajan, You didn't specify which API you are using with Elektron. Is it EMA or Java RFA. For EMA, please see the tutorial on how to setup the build environment here. This will include all the JAR files in the classpath.
For RFA, see this quick start on how to use the bat/sh files for compiling and running the examples that ship with the SDK.
