Required fields for document verification
For document verification samples ( online and postman collection ) are like this
"DataFields": {
"PersonInfo": {
"FirstGivenName": "Mary",
"FirstSurName": "Sample"
"Document": {
"DocumentFrontImage":"Base64 encoded image string goes here",
"DocumentBackImage": "Base64 encoded image string goes here",
"LivePhoto": "Base64 encoded image string goes here",
"DocumentType": "DrivingLicence"
We tried sending a similar message ( we only changed name and surname with name and surname from test entity ) but the verification is not successful due to missing fields ( in this case City, PostalCode, StateProvinceCode ).
The documentation states that for document verification the steps needed are
Step 1 - Say Hello
Step 2 - Test Authentication
Step 3 - Get Country Codes
Step 4 - Get Document Types
Step 5 - Verify
And the description for the last step says
Step 5 - Verify
Once steps 1 through 4 have been completed you should have everything you need to carry out a Verify request. Using one of the country codes from step 3 and the document type from step 4 you can now run a verify request.
Is the documentation missing required steps or are we doing something wrong?
world-checkqual-idqual-id-api
@valter.gelmini
I got a response from the support team.
There are no test entities for Document Verification, so that maybe the issue here. We will be able to test legitimate documents even in a sandbox environment.
The following fields:
will need to be populated with a JPG of PNG file.
