Eikon Data API Error "Asynchronous Query library internal error"
When one of my Eikon clients used Eikon Data API, ek.get_data, it came across following errors.
  1. Error message "Asynchronous Query library internal error"
  2. All of requested fields via Data API ended up with 'nan' in the response values.
Sample RICs as <037833AZ3=>, <DEA1GZCP=>
Client's Python script had successfully been running for 3 months. Above error arose on 17th Feb 2020 and there is no change in client's script so wondering if anything on Eikon API server end and how to fix it.
It's now blocking client's workflow for price discovery so please help with it as quick as possible.
18k 21 12 20
Hi @tony.zhu
Re. client environment, it's Python2.7 so what's the lastet Data API supported? Where to download if any?
- It should be the same library, you can install it using "pip install eikon" command
Re. Datapoint limit associated with the API call get_data, if client hits the limit of 10000 what's the exactly error message popped?
- Please refer to "What happens when a limit is reached?" on the limitation document at https://developers.refinitiv.com/eikon-apis/eikon-data-api/docs?content=49692&type=documentation_item, the response will get truncated or get NaN
What's the meaning of "Asynchronous Query library internal error"?
- I believe that this is not generated from Eikon Data API as I could not locate this error in eikon package source code and I have never seen one.
18k 21 12 20
Hi @tony.zhu
As discussed with you.
I am trying to reproduce the issue with the provided RIC list and fields.
I will update you again tomorrow.
But I think the API call is correct and it may be related to client machine/environment.
Thanks @chavalit.jintamalit for your quick support on this issue.
I compile a RIC list of 2000 RICs RIC_2000.txtas attached so can you help reproduce to see if any issue arises?
ric-2000.txt (21.5 KiB)
18k 21 12 20
Hi @tony.zhu
I cannot reproduce the issue.
Sure, thanks @chavalit.jintamalit.
What about following questions?
  • Re. client environment, it's Python2.7 so what's the lastet Data API supported? Where to download if any?
  • Re. Datapoint limit associated with the API call get_data, if client hits the limit of 10000 what's the exactly error message popped?
  • What's the meaning of "Asynchronous Query library internal error"?
Thank you, @chavalit.jintamalit
Re. 'NaN' in response, it will arise when either no value for requested field or limit is hit, am I right?
Hi @tony.zhu
Sorry, NaN in response should be from the no value for the requested field or any error happen.
