Using Excel 64 bits and xslm Excel workbooks
Data can't seem to refresh since I changed to 64 bits. My XSLX workbooks are fine.
Please help?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonexcel64-bit
@Mathieu_Leclerc
I'm afraid there's not enough detail in your post to diagnose the issue. One thing I should mention is that if you're using Eikon COM APIs in your VBA code, Eikon COM APIs can only be used in 32-bit Excel. If you're not using Eikon COM APIs, then I suggest you open a ticket with Refinitiv Helpdesk to investigate the problem you're experiencing.
