EMA with variable period
I am using python and receive my data via Eikon API.
I want to receive historical EMA datas like 'ema(26,close())'. The 'ema(26,close())' code is working in Eikon Monitor as 'signal(ema(26,close()))'.
I does not see the ema codes in Eikon API - Data Item Browser
Is it possible to receive EMA or other signal datas with different periods from Eikon API?
3.8k 4 4 6
Hi @osmana
You can try this approach:
df,err = ek.get_data('IBM.N',['TR.PRICECLOSE.date','TR.PRICECLOSE'], {'sdate' :'2019-01-01','edate':'0D'})
df['EMA'] = pd.Series.ewm(df['Price Close'], span=26).mean()
df.tail(10)
Hi @marcin.bunkowski
I know the solution but I’m asking about taking Eikon Monitors signals with python.
Is it possible or not?
Regards
Hi @osmana
This is currently not possible. This is the similar question you posted before.
The posted answer was not certain. Thank you.
