VBA: Object variable or with block variable not set
Just got a new computer and trying to get the real time API to work on excel. I followed the installation steps and tried the simplest code from tutorial but it yields me an error "Object variable or with block variable not set".
Below is my code:
Dim WithEvents myRTGet As AdfinXRtLib.AdxRtLi
Sub myRtGetExample()
  Set myRTGet = CreateAdxRtList()
  With myRTGet
      .Source = "IDN"
      .RegisterItems "EUR=", "BID"
      .StartUpdates RT_MODE_IMAGE
  End With
End Sub
' Returns the initial image for the instrument. NOTE - .StartUpdates RT_MODE_IMAGE'
Private Sub myRtGet_OnImage(ByVal DataStatus As AdfinXRtLib.RT_DataStatus)
  ' The value for the specific instrument, specific field, only one in this case.'
  Debug.Print myRTGet.Value("EUR=", "BID")
End Sub
Any idea what is happening ?
Thanks for the help!
eikoneikon-com-api
Check the bitness of Excel. Eikon COM APIs are only available as 32-bit libraries, which can only be used in 32-bit Excel. If you have 64-bit Excel you cannot use Eikon COM APIs in Excel VBA.
Fixed ! Thanks!
