Sudden 401 error
Good day.
Up until about 20 minutes ago, our API calls to the pilot environment has worked perfectly. Since then we've been getting 401 errors.
Our api-key, api-secret, groupID's as well as how we generate the authorization header has remained unchanged.
Can you please confirm whether your pilot environment is working as expected?
Regards.
world-checkworld-check-oneerror-401
4.5k 4 7 8
@gerhardtm,
Thank you for your query.
The API is working fine in the pilot. Could you please share the request / response headers of the failed API call to investigate on the cause of the Error 401?
