All available fields for Eikon tas data
Hi friends!
Could you help me?
1.) Do you know field id for trade direction? is it buy side or sell side
2.) Do you know field id for trade volume? is it "count" field or something else
3.) If you know complete list of all available fields please post
Just to clarify, "field" mean word i put into 'VALUE Bidsize Bid Asksize Ask count' list
data8 = ek.get_timeseries('LCOc1',
start_date='2020-01-21T17:00:00',
end_date='2020-01-21T18:00:00',
fields='VALUE Bidsize Bid Asksize Ask count',
interval='tas'
Best regards, John
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonpricing
18k 21 12 20
Hi @john565
For 1) and 2) You can contact the Refinitiv Content Helpdesk at https://my.refinitiv.com/ to clarify the data behavior.
But I think COUNT is for volume.
For 3)
If you omit the fields parameter in your API call, it will ask for every field.
'fields': [{'name': 'TIMESTAMP', 'type': 'DateTime'},
    {'name': 'EXCHTIME', 'type': 'DateTime'},
    {'name': 'EXCH_SEQUENCE', 'type': 'String'},
    {'name': 'VALUE', 'type': 'Double'},
    {'name': 'TRDPRC_1', 'type': 'Double'},
    {'name': 'COUNT', 'type': 'Double'},
    {'name': 'VWAP', 'type': 'Double'},
    {'name': 'BID', 'type': 'Double'},
    {'name': 'BIDSIZE', 'type': 'Double'},
    {'name': 'ASK', 'type': 'Double'},
    {'name': 'ASKSIZE', 'type': 'Double'},
    {'name': 'PRCTCK_1', 'type': 'Long'},
    {'name': 'BLKVOLUM', 'type': 'Double'},
    {'name': 'EFS_VOL', 'type': 'Double'},
    {'name': 'EFP_VOL', 'type': 'Double'},
    {'name': 'FILTER_CODE1', 'type': 'String'},
    {'name': 'FILTER_CODE3', 'type': 'String'},
    {'name': 'FILTER_CODE4', 'type': 'String'},
    {'name': 'FILTER_CODE5', 'type': 'String'},
    {'name': 'FILTER_CODE6', 'type': 'String'},
    {'name': 'FILTER_CODE7', 'type': 'String'},
    {'name': 'FILTER_CODE8', 'type': 'String'},
    {'name': 'REU_QUAL', 'type': 'String'},
    {'name': 'OPINT_1', 'type': 'Double'},
    {'name': 'TRADE_ID', 'type': 'String'}]
