FINRA minute volumes
Hi, I am downloading minute volumes via Python API with the following code:
data = eik.get_timeseries(['AAPL.O'], "VOLUME", start_date='2020-01-21', end_date='2020-01-22', interval='minute', corax='unadjusted', raw_output=True)
The code works perfectly. Now, I would like to get the values of minute volumes other than FINRA:
How can I achieve this? Is it possible to obtain it via Python or Eikon terminal?
Thank you, Valerio Gemmetto
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonpricing
18k 21 12 20
Hi @valerio.gemmetto
You can contact Refinitiv Content Helpdesk at https://my.refinitiv.com
They will be able to give you an authoritative answer on whether FINRA information is available on Eikon Desktop terminal or not.
