save on_message data
I am working on the websocket python example:
https://github.com/Refinitiv/websocket-api/tree/master/Applications/Examples/EDP/python
I am running the websocket app. I am able to successfully get the response back and close the socket.
I need to collect all the responses while the socket is running and pass the data to another application after the socket is closed.
what would be a good way to do that?
elektron-sdktreprdp-apiwebsocketsrrto
23k 22 9 14
Hello @kshishir,
Elektron Websocket API offers complete flexibility in implementation, what you get is a json-formatted strings, and from the point of the response being received, any paradigm that works with json can be used.
For example,
You can put json in a message and send via any messaging that you prefer, this way is the most time-sensitive.
You can put it in a database, this way requires designing a database structure, but is readily categorize-able and searchable.
The simplest is probably writing it to a file and reading from a file:
Read And Write JSON To A File
Where you should be careful is if your app will re-distribute the streaming content to other users, real time data is exchange-fee-liable, any redistribution must be designed to be exchange-compliant.
