Is it possible to replicate in python the data I see on a chart in real time in eikon? For example, EUR, be able to download the last 2 days on 1 minute data and keep getting the real time updates?
18k 21 12 20
Hi @fredy.sarmiento
First, you can use get_timeseries to get 2 days amount of 1-minute data.
Then if you still want 1-minute data, you can loop the call every 1 minute to get 1-minute data
Or if you need realtime data, you can use StreamingPrice API call to get the realtime data. Please refer to this document.
Thanks a lot !!
Hi @fredy.sarmiento, Replying to you in this thread, since it is more relevant to your new question. As Chavalit mentioned, you can use the get_timeseries API call to get the historical data and combine it with get_data call as described in other thread to get minute updates.
So essentially:
df = ek.get_timeseries('EUR=', fields=['CLOSE'], count=10, interval='minute')
while True:
  df2,err = ek.get_data('EUR=', ['CF_CLOSE'])
  print(df2)
  time.sleep(60)
You might want to append to the dataframe, if you need one continuous series:
df2.columns = ['Instrument', 'CLOSE']
df.append(df2)
                       CLOSE  Instrument
2020-01-21 16:04:00    1.1098        NaN
2020-01-21 16:05:00    1.1098        NaN
2020-01-21 16:06:00    1.1097        NaN
2020-01-21 16:07:00    1.1096        NaN
2020-01-21 16:08:00    1.1097        NaN
2020-01-21 16:09:00    1.1099        NaN
2020-01-21 16:10:00    1.1096        NaN
2020-01-21 16:11:00    1.1097        NaN
2020-01-21 16:12:00    1.1097        NaN
2020-01-21 16:13:00    1.1095        NaN
0                      1.1094       EUR=
There is technical analysis fields available as well (don't seem to be working for FX instruments though):
Get Moving averages:
>>> df3,err = ek.get_data('IBM.N', fields=['TR.Price200DayAverage','TR.Price50DayAverage', 'TR.MovAvgCDSignal', 'TR.PriceMoVolatilityDly'])
>>> df3
  Instrument  200-day SMA  50-day SMA  MACD - Signal  Price Momentum Daily Volatility
0      IBM.N     137.9519    134.8674       0.391135                          1.19946
@Gurpreet !
Many thanks !! much appreciated it.
