Could not load file or assembly 'RFA8_NET100_x64.dll' or one of its dependencies. The specified module could not be found.
Hi All,
We have a WCF Service application(Data Services) which consumes RFA8_NET100_x64.dll library to retrieve business related data.
When I debug this .NET application in visual studio the library(RFA8_NET100_X64.dll) is loading fine we are able to connect to this library via WCF application for data retrieval but when I package and install the WCF application along with "RFA8_NET100_X64.dll" library in some azure environments with Windows Server 2016 installed, we are facing the below error
ERROR:
System.IO.FileNotFoundException: Could not load file or assembly 'RFA8_NET100_x64.dll' or one of its dependencies. The specified module could not be found.
at Eon.DataService.Server.DataConnectors.Reuters.ReutersDataConnector..ctor(String name, String description, IDictionary`2 settings)
Even though the library "RFA8_NET100_x64.dll" is present in the installation directory, application is throwing this error.
Whereas the same package version of WCF application worked well in On premise servers(Windows server 2008), windows 7 and windows 10 machine.
Any kind of help/inputs in addressing this issue is really helpful.
Thanks in Advance.
Sandeep Swargam.
treprfarfa-api
@Sandeep.swargam
It looks similar to this question.
You are using RFA8_NET100_x64.dll so you need to install Microsoft Visual C++ 2010 Redistributable Package (x64) on that machine.
9.7k 49 38 60
Hi @Sandeep.swargam,
It appears the version of RFA .NET you are using is 8.0.x, which is not officially supported on Windows Server 2016 according to the compatibility matrix, i.e.
I would suggest you upgrade your RFA version to the latest (8.1.x) to see if that helps.
Regarding dependencies, although the library: "RFA8_NET100_x64.dll" is present in the installation directory, it is likely complaining about a library that this DLL depends on. You can try to run the depends tool for such situations as it will list dependencies which may not be present, for example:
