Getting Market Holidays with Excel Eikon.
How can I get Market Holidays using Eikon for Excel?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonmarket-holidaysexchange-holidays
4.1k 4 6 11
Try DfListHolidays, example: =DfListHolidays("USA","2019","2020")
Name is usually the same as the ISO code, but there is many other calendar styles. Full list of available styles you can find on: TR-> Utilities->Admin Settings->Style Management->Calendar styles.
It appear it has worked for others, as suggested in this post, In fact, I tried your suggestion and the example proposed in the post as well, but no luck.
What could be the issue? Is there some feature I have to turn on before doing this?
Thanks in advance for your help.
In A5 you use US, should be USA(or USM). In B7 try to cancel {, } and space.
What standard is applied to the country code? It is not the ISO-alpha3 code because this function is using "JAP" for Japan not the ISO "JPN". Where I can get the full list of country code that can be used in this function?
You are right. To find code try to use "=AdStyleAttribute(StyleTable, StyleCode, StyleAttribute)", where: StyleTable - String argument defining the style table; StyleCode - Style code; StyleAttribute - Keyword corresponding to the style attribute
example:=AdStyleAttribute("CUR","JPN","CLDR")
Thank you! But when I try your example in Excel, I always get the "ERROR 3050 - StyleCode : invalid value.". I tried many codes like "JPN", "JAP", "JP", "JAPAN",...etc. Did I missed something?
