We are getting a 401 code on https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/groups This was still working the last week of December and we have not made any code changes.
world-checkworld-check-oneerror-401
2.4k 5 5 5
@Raini-Kevin
401 errors occur because the request has failed an authorization check. This can happen for a variety of reasons, such as
  • An invalid or expired API key,
  • An invalid HMAC signature.
  • Request timing issue/problem with the Date header value. In this scenario, you should ensure a correctly synchronized clock with NTP or the GMT clock is used to generate request timestamps.
  • Incorrect JSON payload formation at your end that can cause a 401 response.
Can you please share the complete request and response for the failed API call so that we can investigate this further?
Thanks,
Mehran Khan
