test3.txttest25.txtObserved that NET.SDK returns less data compared to GUI.
In this case, the notes say it is returning for 25 identifiers, but only data for CLG0 (the first one) is present in extraction - Refer notes Test25.txt.
When I tried doing something similar via the UI it seems to work without issue (the issue is happening only when using the .NET SDK). It wouldn’t make sense to me for this to be a code issue, because if I reduce the list down to 3 RICs I get a response which contains all 3 (notes attached as test3.txt).
