Retrieving historical Index Constituent FTSE
Dear All,
I want to get the constituent of FTSE4Good US Index from 2010-2015. When I type the below formula, I get "NULL" as output. Can you please help? Thanks, Santanu
=TR(".FT4GDBUS";"TR.IndexConstituentRIC;TR.IndexConstituentName;TR.IndexConstituentWeightPercent";"SDate=2015-06-01")
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonindex
18k 21 12 20
Hi @skundu
From the provided code, I believe that you are using Eikon Excel formula.
Please contact helpdesk at https://my.refinitiv.com/
Please select get support >> get product and content support and raise the case to helpdesk.
I did a test and it seems that the data is not available.
Helpdesk will be able to explain why the content is not available and may be able to give you a solution.
