How can i tconfig adh3.3.3 to connect EED in cloud
Hi, i am testing ADH3.3.3 connect to ERT in cloud. but i can not find procedure for tconfig adh in installation guide .
I have machine id and password. Could you give me some advice? Many thanks.
tconfig service_edge -s IDN_RDF
tconfig route_cloud ??
tconfig route_cloud -n trep33 -r route_cloud1 ??
tconfig server_edge -a -s IDN_RDF -i route_cloud1 -n trep33
tconfig adh_rrcp -n trep33
tcommit
rdp-apirefinitiv-data-platformADH
@Qi.Zhu
I also used this command.
tconfig rssl_route -n trep33 -i route_cloud1
The full steps are:
tsetup adh
tconfig rmds_adh_rrcp
tconfig adh_rrcp -n <hostname>
tconfig rssl_route -n <hostname> -i route_cloud1
tconfig route_cloud -n <hostname> -r route_cloud1
tconfig server_edge -s IDN_RDF -i route_cloud1 -n <hostname>
tcommit
Then, I manually added the following entries into the rmds.cnf file.
*adh*serviceDiscoveryUrl : https://api.refinitiv.com/streaming/pricing/v1/
*adh*tokenServiceUrl : https://api.refinitiv.com/auth/oauth2/beta1/token
For the userPassword configuration, please make sure you use dacsObfuscatePassword command to create an obfuscated password.
dacsObfuscatePassword -e <password>
If this doesn't work, please share adh.log file.
@jirapongse.phuriphanvichai thank you. follow your step. the trep can connect to ERT in cloud now.
