I need to configure my proxy server for a Java application for a TRKD application. Can you show me the best way how? Specifically, how I can set up for HTTP and HTTPS traffic?
For HTTP Traffic:
http.proxyHost (default: <none>)
The host name, or address, of the proxy server
http.proxyPort (default: 80) The port number of the proxy server.
http.nonProxyHosts (default: localhost|127.*|[::1])
Indicates the hosts that should be accessed without going through the proxy. Typically this defines internal hosts. The value of this property is a list of hosts, separated by the '|' character. In addition the wildcard character '*' can be used for pattern matching. For example -Dhttp.nonProxyHosts=”*.foo.com|localhost” will indicate that every hosts in the foo.com domain and the localhost should be accessed directly even if a proxy server is specified.
For HTTPS Traffic:
https.proxyHost(default: <none>)
https.proxyPort (default: 443)
Note: The HTTPS protocol handler will use the same nonProxyHosts property as the HTTP protocol.
The same I've tried and it is not working.
It is loading for a long time and always throwing error below mentioned.
2 counts of InaccessibleWSDLException
Please help me on this
