I failed to install Eikon Data API with conda. I got the following error message.
Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000022B8923F630>, 'Connection to pypi.org timed out. (connect timeout=15)')': /simple/eikon/
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000022B8923F860>, 'Connection to pypi.org timed out. (connect timeout=15)')': /simple/eikon/
Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000022B8923FC50>, 'Connection to pypi.org timed out. (connect timeout=15)')': /simple/eikon/
Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ConnectTimeoutError(<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000022B8923FC18>, 'Connection to pypi.org timed out. (connect timeout=15)')': /simple/eikon/
Could not find a version that satisfies the requirement eikon (from versions: )
No matching distribution found for eikon
11.5k 16 7 10
Hello @kyoko
The" 'Connection to pypi.org timed out. " error message means your machine cannot connect to PyPI.org web site to manage and download Eikon Data API via the internet connection. Please consult your IT/Network team.
If you have another machine that can access internet and can download Python library via a pip command, you may try the way in Offline Installation for Eikon Data APIs(Python) article.
I talked with IT team. Thank you so much.
