RData object in COM API
Hi, I have a situation where there are many requests at a time. In order to not get the replies mixed up with each other, I wanted to have a single Dex2Manager that creates multiple RData objects (which are the multiple requests). Would that be a correct way of handling this situation, or is there another/better way?
Thanks.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythoneikon-com-api
@Maya.Uemura
From the question, I assume that you would like to how to get the RData object which can be used inside the OnUpdateEventHandler. There are several ways to do it, such as creating a new class that wraps around the RData object or using the lambda function in .NET.
For the lambda function, the code looks like:
            var myRData = MyDex2Mgr.CreateRData(MyDex2Cookie);
            myRData.OnUpdate += (DEX2_DataStatus DataStatus, object responseError) =>
                Array l_response = myRData.Data as Array;
By using the lambda function, the myRData object can be used inside the OnUpdate event handler.
