How to define custom field for the group. Provide steps to add through UI.
"error": "INVALID_CUSTOM_FIELD",
"cause": "Custom fields which are not defined for the group cannot be used. Available custom fields are provided in the group's case template."
world-checkworld-check-onefields
2.4k 5 5 5
@Onkar.Arora
Before you add the custom fields to your request payload, you will have to create them using the WC1 UI->admin section-> under product settings ->Screening custom fields->edit
Please refer to the below-existing dev com question for a detailed explanation:
https://community.developers.refinitiv.com/questions/38791/how-to-set-customfields-for-my-request.html
Let me know if you need more information.
Regards,
Mehran Khan
