Hi Team,
I've download and trying to run ETA Consumer as per the below doc,
Changed the ELEKTRON_JAVA_HOME and binary versions into 3.4.0.0. The compilation is success but failed while running the first tutorial. Is there i need to specify the http lib or need to configure some file(s)?
I cross verified few files and couldn't find config related to http lib. Any help or suggestion much appreciated. Thank you!
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/http/HttpHost at com.thomsonreuters.upa.valueadd.reactor.ReactorOptions.clear(ReactorOptions.java:343) at com.thomsonreuters.upa.valueadd.reactor.ReactorOptions.<init>(ReactorOptions.java:60) at com.thomsonreuters.upa.valueadd.reactor.ReactorFactory.createReactorOptions(ReactorFactory.java:90) at com.thomsonreuters.upa.tutorials.valueadd.consumer.tutorial2.basicConsumer.<init>(basicConsumer.java:70) at com.thomsonreuters.upa.tutorials.valueadd.consumer.tutorial2.basicConsumer.main(basicConsumer.java:416) Caused by: java.lang.ClassNotFoundException: org.apache.http.HttpHost
