How to determine instrument type?
Is there a way to distinguish between two RICs that have the same FID 259 but different instrument type? For example, CNH1M= and CHF40P5M=R both have an FID 259 of 209. On the RIC lookup tool they have instrument types of A:54 and I:AF. Is this information included in the messages?
elektronrefinitiv-realtimeelektron-sdkricssymbologyrecordtype
23k 22 9 14
Hi @qsiano,
Try FID1, PROD_PERM, permission that is required to consume the instrument.
Using your example,
CHF40P5M=R has FID 1= value 7002
GBP40P5M=R also has FID 1 1=value 7002
while
CNH1M= has FID 1=value 5454
This is more fine-grained then instrument type, as different exchanges will have the same instrument type denoted with different PEs.
However, to get a definitive answer on content, better to ask a content expert directly, consider contacting Refinitiv Helpdesk Online or dialing your local Refinitiv helpdesk number.
@zoya.farberov Thanks, I will try that. Do you know if there is a resource to look up the PROD_PERM for each RIC?
@qsiano,
I do not know of a dedicated lookup tool.
The most straightforward is to subscribe the instrument via any example or custom consumer, rmdstestclient ftool rom Infra Tools package, or Eikon if you are a an Eikon customer-> Quote tool-> View all fields
Ok, thanks
