Key error: 'eikon'
Just starting out using the API and ran into a Key Error issue
My code is below:
import eikon as ek
import configparser as cp
import cufflinks as cf
cfg = cp.ConfigParser()
cfg.read('eikon.cfg')
ek.set_app_key(cfg['eikon']['*This is my app key*'])
rics = ['JKMc1','TRGBNBPMc1']
print(rics)
eikon-data-apielektronrefinitiv-realtimeelektron-sdk
@vincent.turner
It looks like to be the error message from the configparser library.
From my testing, the eikon.cfg should have the following entries:
[eikon]
appkey = <appkey>
Please replace the <appkey> with your application key.
Then, the appkey can be used in the ek.set_app_key method with the following code.
ek.set_app_key(cfg['eikon']['appkey'])
