The question in the subject
Yes, you can retrieve this field using AdxRtList object of AdfinX Real-Time library (aka RTX).
Historical reasons. This field has been part of real-time data record for decades since before fundamental & reference dataset even existed within what was Reuters then. Today you can also retrieve data contained in OFFCL_CODE field from fundamental & reference dataset using DEX2 library and fields TR.CUSIP, TR.ISIN etc.
I couldn't get OFFCL_CODE from dex2.
Do you mean TR.CUSIP has the same data as OFFCL_CODE?
