Additional information of Screening Results
I am looking at getting more information on the screening results.
On the portal when you click on the matched results you get more information about the same.
Is there a way to get these information through api?
world-checkworld-check-onescreening-api
4.2k 7 5 6
@info35
Yes, please use the API call ""SEQ-case-investigate-world-check-profile: Get a World-Check profile" to get more information about each match that is present in the screening result.
Please use the attribute "referenceId" attribute found in the screening result (there will be an unique referenceId for each match) as the parameter for the mentioned API cal.
