I got a trial on Elektron Connect APIs/SDK, but there is an exception occurred as below:
Dec 10, 2019 3:08:54 PM com.thomsonreuters.ema.access.ChannelCallbackClient reactorChannelEventCallback
warning: loggerMsg
Severity: Warning
Text: Received ChannelDownReconnecting event on channel Channel
RsslReactor Channel is null
Error Id 0
Internal sysError 0
Error Location Reactor.processWorkerEvent
Error text Reconnection failed: java.nio.channels.UnresolvedAddressException
loggerMsgEnd
and main code as below, I think the problem should on: config.host("elektron:14002").username("test"), reqMsg.serviceName("ELEKTRON_AD").name("IBM.N"), any help?
public class Consumer { public static void main(String[] args) { OmmConsumer consumer = null; try { AppClient appClient = new AppClient(); OmmConsumerConfig config = EmaFactory.createOmmConsumerConfig(); consumer = EmaFactory.createOmmConsumer(config.host("elektron:14002").username("test")); ReqMsg reqMsg = EmaFactory.createReqMsg(); consumer.registerClient(reqMsg.serviceName("ELEKTRON_AD").name("IBM.N").interestAfterRefresh(false), appClient); Thread.sleep(60000); // API calls onRefreshMsg(), onUpdateMsg() and onStatusMsg() } catch (InterruptedException | OmmException excp) { System.out.println(excp.getMessage()); } finally { if (consumer != null) consumer.uninitialize(); } } }
