RIC asserted as invalid even though it is returned by an Eikon function.
Hi friends,
I have queried a particular ship's RIC based on its IMO in the python language like so:
RIC_code = ek.get_symbology("9040455", from_symbol_type="IMO", to_symbol_type="RIC")
RIC_code
the response is
RIC9040455C}KM7309468913
But when I use the returned RIC in a subsequent query
data2 = ek.get_timeseries('C}KM7309468913', # the RIC
fields='*', # all fields
start_date='2019-09-01', # start date
end_date='2019-10-31') # end date
I get an error response :
Error with C}KM7309468913: Invalid RIC C}KM7309468913: Invalid RIC | .
Is there a way to get past this to the data I want?
Thank you.
18k 21 12 20
Hi @ivan.markose
This is not a valid RIC on quote or timeseries database.
Please use "Data Item Browser" to explore what field you are interested in.
And please use get_data() to get the information.
(You may click on Parameter to see any supported parameters too)
Example using get_data():
6.7k 8 6 7
@ivan.markose Its a physical asset RIC - in this case a ship - so as Chavalit points out it will not have any timeseries as such - so you should use get_data() call with appropriate fields by checking Data Item Browser to see what is available.
Hi Jason,
Thank you. Yes I now understand how to use the get_data() function
Thank you
Ivan
