Problem with consumer application
After creating a client id using the app key generator... i get this error msg
any ideas? thanks
Thread 1 "FX_MktDataClien" received signal SIGINT, Interrupt.
0x00000034f74df5b7 in ppoll () from /lib64/libc.so.6
(gdb)
Continuing.
loggerMsg
TimeStamp: 09:08:18.305
Severity: Warning
Text: Received ChannelDownReconnecting event on channel Channel_3
Instance Name Consumer_3_1
RsslReactor 0x0xd565c0
RsslChannel 0x0xd565c0
Error Id -1
Internal sysError 0
Error Location /local/jenkins/workspace/ESDKCore_RCDEV/OS/RH6-64/rcdev/source/esdk/Cpp-C/Eta/Impl/Reactor/rsslReactorWorker.c:1186
Error Text </local/jenkins/workspace/ESDKCore_RCDEV/OS/RH6-64/rcdev/source/esdk/Cpp-C/Eta/Impl/Transport/ripcsslutils.c:1033> Error: 2002 Certificate valida\
tion error. OpenSSL Return code: self signed certificate in certificate chain
loggerMsgEnd
elektronrefinitiv-realtimeelektron-sdkconsumer
7.6k 15 6 9
@epfeuffer
Starting with version ESDK 1.3, you must install OpenSSL if you intend to use encrypted connections.
Based on the codes provided in the ESDK package, the message was returned from OpenSSL library on your Linux server.
According to the following document
https://www.openssl.org/docs/man1.0.2/man3/X509_verify_cert_error_string.html
The following message is a description for the text.
X509_V_ERR_SELF_SIGNED_CERT_IN_CHAIN: self signed certificate in certificate chain
the certificate chain could be built up using the untrusted certificates but the root could not be found locally.
It seems to be a problem with OpenSSL Installation. I would suggest you re-install or upgrade the OpenSSL library on the Linux server.
23k 22 9 14
Hello @epfeuffer and all,
Noting that the previous answer by @moragodkrit was correct, adding OpenSSL library to PATH helped to resolve the above error message.
