recreate Rhistory function through VBA
I managed to get the Eikon VBA API up and running with the following parameters (from the example file) :
Instrument GB0008754136
Fields TRDPRC_1.TIMESTAMP;TRDPRC_1.VALUE;TRDPRC_1.VOLUME
Request Mode NBROWS:25 INTERVAL:TICK CODE:MULTI
RefreshParams FRQ:5S
DisplayParams SORT:D CH:Fd
Now I would like to recreate the following Rhistoryfunction according to that parameter layout : =RHistory("TRGBNBPD1";".Timestamp;.Close";"START:41275 END:43789 INTERVAL:1D";;"SORT:ASC TSREPEAT:NO CH:Fd";G12) . How do I convert it from that history function to the necessary parameters to utilize in the VBA API?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythoneikon-com-api
@dmdeclercq
The following is the syntax of the RHistory function:
=RHistory("Instruments","[Fields]","Request","[Refresh]","[Display]",[Destination Cell])
I think you can apply it to the parameters of the RHistory VBA API.
For more information regarding the RHistory VBA API, please refer to Tutorial 9 - Time Series History - RHistoryAPI.
