I'm migrating from ETA 3.1.0L1 to 3.4.0L1 (Elektron-SDK-1.4.0L1).
The Linux upgrade went fairly smoothly - some includes and libraries have moved around, however it builds and passes it's test suite.
On Windows (VC11) not so much.
We are getting persistent multiply & undefined symbols at link time.
1>librsslVACache.lib(d_main.obj) : error LNK2005: _ansi_pch already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: _ansi_param already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: _ansi_spesc already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: _ansi_chparm already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: qa_decode already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: qa_end_of_row already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: qa_page_columns already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: qa_page_rows already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: qa_scroll_bot already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: qa_set_columns already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: qa_set_end_of_row already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: qa_set_rows already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: qa_set_scroll_bot already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: null_char already defined in librsslVACache.lib(d_main.obj) 1>librsslVACache.lib(d_main.obj) : error LNK2005: _ansi_do_decode already defined in librsslVACache.lib(d_main.obj) 1> Creating library C:\src\Agora\trunk\outwell\VC11\x64\binr\libs\agora_lib_UPA.x64.lib and object C:\src\Agora\trunk\outwell\VC11\x64\binr\libs\agora_lib_UPA.x64.exp 1>librssl.lib(ripcsslutils.obj) : error LNK2019: unresolved external symbol __imp_CertCloseStore referenced in function ripcSSLSetupCTXClient 1>librssl.lib(ripcsslutils.obj) : error LNK2019: unresolved external symbol __imp_CertEnumCertificatesInStore referenced in function ripcSSLSetupCTXClient 1>librssl.lib(ripcsslutils.obj) : error LNK2019: unresolved external symbol __imp_CertFreeCertificateContext referenced in function ripcSSLSetupCTXClient 1>librssl.lib(ripcsslutils.obj) : error LNK2019: unresolved external symbol __imp_CertOpenSystemStoreA referenced in function ripcSSLSetupCTXClient 1>C:\src\Agora\trunk\outwell\VC11\x64\binr\agora_lib_UPA.x64.dll : fatal error LNK1120: 4 unresolved externals
We include the following libraries
librsslVA.lib librsslVACache.lib libdacs.lib libansi.lib librssl.lib
Is there a problem with the Package or am I missing something?
