Service name alias for RFA
Is there a way for us to configure RFA to translate the service request by the code to something else?
The situation is , our application hard coded to request for "IDN" service. We want them to test "ETE" service , and they cannot do that without changing the code.
If we can do this via RFAJ & RFA C++ config file that would be great.
treprfarfa-api
7.6k 15 6 9
@Kung.S
You may need to set the services alias in RFA configuration file.
You can find the details from RFA C++ Configuration Guide
section C.1 Change Service Name
You might need to add service alias "IDN" to RFA configuration file like the following sample
\Services\IDN\feedName = "<Real Service on TREP>"
And then add “IDN” to serviceList of your connection.
\Connections\<Your Connection Name>\serviceList = "IDN"
And then your app should be able to request service IDN and it will translate to feedName you specified.
I did a quick test with RFASTTIcker and StarterConsumer and it seems to works.
Great. Can I assume it is the same with RFA Java?
7.6k 15 6 9
@Kung.S As far as I know, Java also has the configuration as well.
11.3k 25 8 13
Hi @Kung.S,
RFA Java have similar parameters, so it should work with RFA Java.
