We would like to implement app with recommendation under Appendix A in ETA developer guide. ETA will connect to local TREP.
Please advice how to simulate case with real environment for test application developed by ETA.
Hello @danai.ongvuttivate
One possible way is to use sink_driven_src interactive mode. The tool is in TREP Infrastructure Tools which can be download from ELEKTRON SDK - TOOLS .
The diagram
sink_driven_src --> TREP --> ETA
For example
sink_driven_src -S DIRECT_FEED -N 14002 -K -C 5000 -c -K -E rssl
wait till ETA receives an image
2. at sink_driven_src console, to see status command options press s then enter.
3. I typed unsol_stale_status and Enter number of Item 1 (I subscribed one item). Then, the application will receive Open/Suspect/None status message
4. When I wanted data to come back, I typed d to see data command options, Then, I typed unsolicited_image and item name that I had subscribed. Next, the application will receive data again:
Please refer to Install.pdf shipped with the package for more details of this tool.
For any question about TREP or this tool, I would suggest you reach out to the TREP Support team who is expert and can help you. You can submit the questions to the team directory via MyRefinitiv and select product Thomson Reuters Enterprise Platform . For any difficulties submitting the query, please contact Refinitiv Account team.
Hope this help.
Thanks. BTW, may I confirm if STREAM STATE and DATA STATE in APPENDIX A is the same thing as Status Message Interface in 12.2.4?
