How can I get the index constituents with float shares and Total Shares via API COM at any given date ?
I tried to retrieve data using DEX2 TimeSeries with :
Item list : 0#.FCHI
Fields : TR.IndexConstituentRIC;TR.FreeFloat
Request Parameters : '"Sdate":"2019-10-31"
The IndexConstituent is right but the free float is wrong for all the securities.
Thank you for your help.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonindex
18k 21 12 20
Hi @h.k
I can confirm that the DEX2 API retrieves the data correctly in technical point of view.
(But I cannot confirm if the data is correct or not)
To clarify on the content, please contact Refinitiv Content Helpdesk at https://my.refinitiv.com/
18k 21 12 20
Hi @h.k
I tried to retrieve TR.FreeFloat on a few instruments using Data Item Browser and using DEX2 API.
I received the same data.
Can you share your result please?
Thanks.
Thank you for your reply.
I expected to get the float shares of CAC40/01 Quote which are real time values (see attached CaptureCAC01). For example, the float shares of ACCP.PA is TotalShares * Float = =270045923*0,7 = 189032146,1.
However, when I retrieve data using DEX2 TimeSeries TR.SharesFreeFloat and SDate=20191106, I get a different value (see attached CaptureDEX2).
