DSWS connection via python client api issue.
I have installed the DSWS via pip install and have valid username and password.
I imported the package using:
import DatastreamDSWS as dsw
and used following code to connect:
ds = dsw.Datastream(username='****', password='******')
But when I try to connect datastream from python notebook , i get following message:
User '******' not entitled to ClientApi service
datastream-apidsws-apiconnection
1.1k 3 3 3
@Mahesh.A Kulkarni
Based on the error message your ID is not entitled for the service. I would advise contacting Refinitiv Help Desk to confirm if the ID is correctly entitled.
Please note that credentials for Datastream Web Service are Datastream Child ID starting with Z and corresponding password.
@Mahesh.A Kulkarni
I have also noticed that you used dsw instead of dsws when installing the package.
Correct path is:
import DatastreamDSWS as dsws
ds = dsws.Datastream(username='XXXXXXX', password='XXXXXXX')
@Monika.Stankovic
Hi, I have used dsw as an alias both while importing and calling datastream. Ideally it should not be an issue.However, upon your suggestion i made the changes you suggested but i still get the same error.
@Monika.Stankovic, i have received the child id starting with 'Z' along with the password last Friday. I am able to login to the portal using these same credentials. Can you please share link or email id of help desk whom i can contact to get the issue resolved.
@Mahesh.A Kulkarni
You can raise a query via below link or if you have Eikon application by using Contact Us capability (click the button in the top left corner of Eikon and in drop down list select Help > Contact Us):
https://my.refinitiv.com/content/mytr/en/signin.html
@Monika.Stankovic thanks so much for the help....
