Individual estimates not matching series
Hello Eikon QA,I seem to have some consistency problems when im retriving data (TR.PtoEPSMeanEst and TR.FwdPtoEPSSmartEst) from the API individually, as a series or from the data item browser. For example:
Retrieve all in a single call as a series:
df = ek.get_data('AAPL.OQ', ['TR.PtoEPSMeanEst'], {'SDate':'0','EDate':'3','Frq':'FY','Period':'FY1'})
I obtain the following result:
Instrument  Price / EPS (Mean Estimate)
0    AAPL.OQ                    12.187330
1    AAPL.OQ                    16.823317
2    AAPL.OQ                    15.606444
3    AAPL.OQ                    17.793991
However if i do try to retrieve each of the elements individually:
df = ek.get_data('AAPL.OQ', ['TR.PtoEPSMeanEst(Period=FY1)','TR.PtoEPSMeanEst(Period=FY2)','TR.PtoEPSMeanEst(Period=FY3)','TR.PtoEPSMeanEst(Period=FY4)'])
I get a different result for the FY1:
0    AAPL.OQ                     19.21973
1    AAPL.OQ                     16.823317
2   AAPL.OQ                      15.606444
3   AAPL.OQ                      17.793991
And finally if i check the DIB i get yet another result for the first year 19.2277:
There seems to be a wrong result in the value of 12.18 since AAPL hasnt had that PE ratio in a very long time. What is wrong? Did i use an incorrect query?
If i do the same operations for EBITMean, the API results are aligned. Thanks in advance for your help. Best regards
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythondatadata-item-browser
18k 21 12 20
Hi @ant1bball
I believe that this is the equivalent call:
