How to use screener to select RICs from multiple countries?
Hello.
Normally if we wish to select RICs from a single country, we could use the screener expression like: SCREEN(U(IN(Equity(active,public,primary))),IN(TR.ExchangeCountryCode,"FR"), CURN=USD)
However, how do we modify the above screener expression to specify a list of countries?
Thank you.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonscreenercountry-code
18k 21 12 20
Hi YC,
You can follow the same answer in your previous question.
https://community.developers.refinitiv.com/questions/50831/how-to-retrieve-full-lists-of-all-exchanges-indice.html?childToView=50841#answer-50841
You can select multiple countries and see the generated syntax.
