DSS API: Fund Search
Hello, I'm trying to use the DSS Search API for specific funds, using the DomicileCode and SubType parameters. Is there a way to automatically and dynamically link the output of that search to a Report Template extraction (e.g. Terms and Conditions) in order to get a dynamic output?
Thanks in advance and best regards,
Aurélien
dss-rest-apidatascope-selectdssfundsreport-templateterms-and-conditions
Hi Aurelian,
Don't believe there's any other option but to run a Fund search request to get the results first, nest the results as list items, then run the extraction.
The closest this type of request sounds like in terms of direct dynamic functionality would be the criteria lists / screneers which can be used against schedules but believe only Commodities, DTC and Loans criterias are available.
Best regards,
Gareth
Thanks Gareth, indeed that is what I had in mind. Thanks for the confirmation!
Best regards,
Aurélien
