How do I get a list of the current consituents of an index using the DSS REST API
I should retrieve on a monthly basis the list of the securities that constitute some of the populat indexes, over the DSS REST API, with a .Net application. Any idea how to do that ?
I can't find any mention of index anywhere, and the chains search (which could be one answer) in the DSS GUI does not find such a thing as the .DJI or ^DJI, although the latter is supposed to be the RIC code of the Dow Jones index, and the chains search want to have a RIC code...
Any help very welcome !
Regards
Bernard
dss-rest-apidatascope-selectdssindex
11.3k 25 8 13
@BTh
Hi Bernard,
Normally, there could be Chain RIC which provides list of constituent RICs. You can use the Chain RIC to retrieve list of constituent RICs with TermsAndConditions extraction. Below is the example code. As far as I know, the Chain RIC for .DJI is 0#.DJI.
For Chain RICs of other index, please contact Content support via MyRefinitiv.
    var extractionsContext = new ExtractionsContext(new Uri("https://hosted.datascopeapi.reuters.com/RestApi/v1/"), dssUserName, dssUserPassword);
    TermsAndConditionsExtractionRequest extractionRequest = new TermsAndConditionsExtractionRequest
        IdentifierList = InstrumentIdentifierList.Create(
            new[] { new InstrumentIdentifier { Identifier = "0#.DJI", IdentifierType = IdentifierType.ChainRIC } }, null, false),
        ContentFieldNames = { "RIC" },
        Condition = new TermsAndConditionsCondition
            IssuerAssetClassType = IssuerAssetClassType.AllSupportedAssets,
            ExcludeWarrants = false,
            //StartDate = new DateTimeOffset(DateTime.Now)
    var extractionResult = extractionsContext.ExtractWithNotes(extractionRequest);
    var extractedRows = extractionResult.Contents;
    //Output
    if (!extractedRows.Any())
        Console.WriteLine("No rows returned");
    else
        foreach (var row in extractedRows)
            Console.WriteLine(
                row.Identifier + " (" + row.IdentifierType + ") " +
                String.Join(", ", row.DynamicProperties.Select(dp => dp.Key + "=" + dp.Value)));
