Error 401 - Groups (Working in Postman but neither in Vue Js neither in Php)
I'm using a demo access to the worldcheck api.
I have my key and my secret key.
Postman is working. I have access and results.
I've 401 Unauthorised Access problems when I try to implement the access through frontend (vuejs using either fetch or axios) or through backend (php).
For vue js, I adapted the nodejs example. And the code is really similar (javascript in both cases).
I also compared the authorization header i'm getting in postman and in vue js and they are identical.
Here is an example :
- Vue JS -
Date: Thu, 24 Oct 2019 14:39:52 GMT
Authorization: Signature keyId="******************************",algorithm="hmac-sha256",headers="(request-target) host date",signature="bhT39ij/iE1851ZH402zYahPmAEZtkK/riL/CQvvM4w="
- PostMan
Authorization: Signature keyId="***************************",algorithm="hmac-sha256",headers="(request-target) host date",signature="bhT39ij/iE1851ZH402zYahPmAEZtkK/riL/CQvvM4w="
I would welcome any support or hint of explorations.
Thanks in advance,
Best regards,
Emmanuel
Here is the vue js code :
<template>
<div>
WORLDCHECK
</div>
</template>
<script>
import CryptoJS from 'crypto-js'
export default {
mounted () {
this.initialize()
methods: {
generateAuthHeader(dataToSign){
var hash = CryptoJS.HmacSHA256(dataToSign,process.env.worldcheck.WC1_APISECRETKEY);
return hash.toString(CryptoJS.enc.Base64);
initialize () {
var gatewayhost = process.env.worldcheck.WC1_GATEWAYHOST;
var gatewayurl = process.env.worldcheck.WC1_GATEWAYURL;
var apikey = process.env.worldcheck.WC1_APIKEY;
var apisecretkey = process.env.worldcheck.WC1_APISECRETKEY;
var date = new Date().toGMTString();
console.log("date", date);
var datas = "";
var dataToSign = "(request-target): get " + gatewayurl + "groups"
+ "\n" + "host: " + gatewayhost
+ "\n" + "date: " + date
// + "\n" + "content-type: " + "application/json"
// + "\n" + "content-length: " + datas.length
// + "\n" + datas
console.log("dataToSign", dataToSign);
var hmac = this.generateAuthHeader(dataToSign);
console.log("hmac", hmac);
//var authorisation = 'Signature keyId="' + apikey + '",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length",signature="' + hmac + '"';
var authorisation = 'Signature keyId="' + apikey + '",algorithm="hmac-sha256",headers="(request-target) host date",signature="' + hmac + '"';
console.log("authorisation", authorisation);
// GET headers is just date & authorization, no body
var headers = {"Date": date, "Authorization": authorisation};
//var headers = {"currentdate": date, "authorization": authorisation};
console.log("headers", headers);
var url = 'https://'+gatewayhost+ gatewayurl + 'groups';
console.log("url", url);
fetch(url, {method: 'GET', headers: new Headers(headers)})
.then(response => {
console.log("THIS SHOULD HAVE DATA", response.data);
this.result = response.data
.catch(error => {
console.log('fetch',error)
layout:"layout_steps"
</script>
<style>
</style>
Here is the php code :
<?php
require_once('./apiinfo.php');
header("Content-Type: application/json; charset=utf-8");
header('Access-Control-Allow-Origin: *');
header('Access-Control-Allow-Methods: GET, POST, OPTIONS, PUT, PATCH, DELETE');
header('Access-Control-Allow-Headers: X-Requested-With, content-type, Authorization');
$gatewayhost = WC1_GATEWAYHOST;
$gatewayurl = WC1_GATEWAYURL;
$apikey = WC1_APIKEY;
$apisecretkey = WC1_APISECRETKEY;
$dateTime = new DateTime('now GMT');
$date = $dateTime->format('D, d M Y H:i:s') . ' GMT';
$dataToSign = "(request-target): get " . $gatewayurl . "groups"."\n" . "host: " . $gatewayhost . "\n" . "date: " . $date;
$hmac_brut = hash_hmac('sha256', $dataToSign, $apisecretkey);
$hmac = base64_encode($hmac_brut);
$authorisation = "Signature keyId=\"" . $apikey . "\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date\",signature=\"" . $hmac . "\"";
//$headers = {'Date': $date, 'Authorization': $authorisation};
$curl = curl_init();
curl_setopt_array($curl, array(
CURLOPT_URL => "https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/groups",
CURLOPT_RETURNTRANSFER => true,
CURLOPT_ENCODING => "",
CURLOPT_MAXREDIRS => 10,
CURLOPT_TIMEOUT => 30,
CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1,
CURLOPT_CUSTOMREQUEST => "GET",
CURLOPT_HTTPHEADER => array(
"Accept: */*",
"Accept-Encoding: gzip, deflate",
"Authorization: ".$authorisation,
"Cache-Control: no-cache",
"Connection: keep-alive",
"Date: ".$date,
"Host: rms-world-check-one-api-pilot.thomsonreuters.com",
"cache-control: no-cache"
$response = curl_exec($curl);
$err = curl_error($curl);
curl_close($curl);
if ($err) {
print(json_encode("cURL Error #:" . $err));
} else {
print( $response ? $response : json_encode("EMPTY RESPONSE"));
world-checkworld-check-oneerror-401
2.4k 5 5 5
@emmanuel.blanc
on the PHP code front, I see that when you are declaring the hmac function you are missing a parameter "raw_output".
"$hmac_brut = hash_hmac('sha256', $dataToSign, $apisecretkey); "
Can you please go through the below link for more insights
https://www.php.net/manual/en/function.hash-hmac.php
And about the node.js request, can you please share the complete request and response headers so that we can investigate it further?
Regards,
Mehran Khan
2.4k 5 5 5
@emmanuel.blanc
I'm looking into the details that you have provided, please allow me some time to get back with my analyses.
Regards
Hi Mehran,
Thank you very much for your hint in php. It helped to solve the problem. I will get it through backend.
In case you have any clue for the front end part (why does it not work), I added any the detailed information below.
Anyway I can now go on, and many thanks.
Best regards,
Emmanuel
- Vue JS
I'm not using node js but vue js, a front-end framework in javascript with axios or fetch (<=> ajax) to access data.
In this configuration, I compared the hmac between postman and vuejs and it's the same.
I managed to send the request at the same second so it's easy to compare.
--> Here is the node js native code postman give to me :
var http = require("https");
var options = {
"method": "GET",
"hostname": [
"rms-world-check-one-api-pilot",
"thomsonreuters",
"com"
"path": [
"v1",
"groups"
"headers": {
"Date": "Mon, 28 Oct 2019 09:36:06 GMT",
"Authorization": "Signature keyId=\"a13d27fe-0a3e-4d82-85b7-5e07fd71576a\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date\",signature=\"tvhM/ZzibTm7qN+Fsd/75JMjah41ZIhiYa7tGDW4yok=\"",
"User-Agent": "PostmanRuntime/7.19.0",
"Accept": "*/*",
"Cache-Control": "no-cache",
"Postman-Token": "ea60eb62-12f2-4b56-8a69-5fc1f0ee84ad,94042e62-709a-4f68-b731-f223b9882b25",
"Host": "rms-world-check-one-api-pilot.thomsonreuters.com",
"Accept-Encoding": "gzip, deflate",
"Connection": "keep-alive",
"cache-control": "no-cache"
var req = http.request(options, function (res) {
var chunks = [];
res.on("data", function (chunk) {
chunks.push(chunk);
res.on("end", function () {
var body = Buffer.concat(chunks);
console.log(body.toString());
req.end();
--> Here is the httt request postman give to me :
GET /v1/groups HTTP/1.1
Date: Mon, 28 Oct 2019 09:36:06 GMT
Authorization: Signature keyId="a13d27fe-0a3e-4d82-85b7-5e07fd71576a",algorithm="hmac-sha256",headers="(request-target) host date",signature="tvhM/ZzibTm7qN+Fsd/75JMjah41ZIhiYa7tGDW4yok="
User-Agent: PostmanRuntime/7.19.0
Accept: */*
Postman-Token: ea60eb62-12f2-4b56-8a69-5fc1f0ee84ad,d000bbc6-202d-499d-917b-6fd446de4608
--> Here is the vue js parameters :
date: Mon, 28 Oct 2019 09:36:06 GMT
authorization: Signature keyId="a13d27fe-0a3e-4d82-85b7-5e07fd71576a",algorithm="hmac-sha256",headers="(request-target) host date",signature="tvhM/ZzibTm7qN+Fsd/75JMjah41ZIhiYa7tGDW4yok="
- settings
var settings = {
"async": true,
"crossDomain": true,
"url": "https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/groups",
"method": "GET",
"headers": {
"Date": date,
"Authorization": authorisation,
"User-Agent": "PostmanRuntime/7.18.0",
"Accept": "*/*",
"Postman-Token": "1785229a-a598-46dd-b2e5-5f8b0c2d1f04,c31fcdb7-8767-4175-a276-5170bd6321ff",
- Header Response as given by Firefox
HTTP/1.1 401 Unauthorized
X-Application-Context: application
Authorization: WWW-Authenticate: Signature realm="World-Check One API",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length
Allow: GET, HEAD, POST, PUT, DELETE, TRACE, OPTIONS, PATCH
Transfer-Encoding: chunked
Server: ""
- Header Request as given by Firefox
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:70.0) Gecko/20100101 Firefox/70.0
Accept: */*
Accept-Language: fr,fr-FR;q=0.8,en-US;q=0.5,en;q=0.3
Accept-Encoding: gzip, deflate, br
Access-Control-Request-Method: GET
Access-Control-Request-Headers: authorization,cache-control,postman-token,user-agent
Referer: http://localhost:3000/worldcheck
Origin: http://localhost:3000
DNT: 1
Pragma: no-cache
