Hello, where can I find the ChainRic for options on Bund futures (OGBL) ? Thanks
@ayoub.serroukheidrissi,
this forum is focused on technical API queries, we are not data specialists.
That said, often the chain RICs start with "0#". I therefore attempted a quick search in Eikon for "0#OGBL", and found several chains:
If you have Eikon you can do the same search, you will see all the chains around OGBL.
Does this help ?
