I have a problem pulling raw template data in TRTH via API, can you help?
I am trying to search data for the RIC IBM.NOI (which is a NYSE Order imbalance RIC) via restful API, however I receive no results for the FIDs I query. When I run the search within the GUI, I receive data without issue, therefore I believe there is a problem with my call.
I am using:
POST https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/ExtractRaw
"ExtractionRequest": {
"@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.TickHistoryRawExtractionRequest",
"IdentifierList": {
"InstrumentIdentifiers": [
{ "Identifier": "IBM.NOI", "IdentifierType": "Ric" }
"ValidationOptions": {"AllowHistoricalInstruments": true},
"UseUserPreferencesForValidationOptions": false
"Condition": {
"MessageTimeStampIn": "GmtUtc",
"ReportDateRangeType": "Range",
"QueryStartDate": "2019-10-07T12:00:00.000Z",
"QueryEndDate": "2019-10-09T12:10:00.000Z",
"ExtractBy": "Ric",
"SortBy": "SingleByRic",
"DomainCode": "MarketPrice",
"Fids": "4335,4337,4338,4339,4340,4341",
"DisplaySourceRIC": true
When I attempt to retrieve the data I only get the headers, and no actual content.
Can you suggest any fixes?
tick-history-rest-apiapirics
13.7k 26 8 12
@jack.coppinger1,
your API request looks fine to me, I don't see any issues with the syntax. As I can't run it due to the permissioning, all I can do is give you suggestions to try out. Could you try the following:
  • Remove the FID filter line from your API query ("Fids": "4335,4337,4338,4339,4340,4341", )
  • Select a wider date range for your API query, something like 1 or 2 weeks of data (I can't see the time stamps in your screenshot, so I don't know if they are inside the range of the API query).
Does that deliver any data ?
If not, what do the extraction notes contain, can you post them ?
13.7k 26 8 12
@jack.coppinger1,
I tried your request, but I am not permitted for data for this instrument in TH (I get the following message in the extraction Notes: row suppressed for lack of 'NOI (NYSE ORDER IMBALANCE)' permission.\nReport suppressed because no instruments are permitted\n).
That said, I cannot get any data for it in Eikon either. It might just be that there is no data ?
I suggest you do the following:
  1. Ensure you are permitted to access this data (do you get the same message as I in the extraction notes ?)
  2. Check with a data specialist if there is any data for this instrument and that time period.
Hi Christaan,
Thank you for your prompt reply. This is a special content set available from NYSE that must be permissioned on your TRTH A/C and Eikon. I got the permission team to add it to my TRTH A/C, and used the raw template within the GUI to pull the attached data, so the data is definitely there, but I don't seem to be able retrieve it via API.
Thanks,
Jack
