500 internal server error
Morning, i am facing today severe issues with get_time_series on the Eikon Python api:
File "...\lib\site-packages\eikon\json_requests.py", line 194, in _check_server_error
raise EikonError(int(server_response['ErrorCode']), error_message)
eikon.eikonError.EikonError: Error code 500 | Backend error. 500 Internal Server Error
What is the workaround? i need an urgent answer. thank you
I'm also facing this issue. Usually, I can handle these errors by waiting 1 second and repeating the request but today a large portion of the requests return Backend error. 500. I haven't faced this issue over the past few months. Please help.
Hello @Mehdi and @miguel.costa,
Can you confirm is the issue is still persist in your environments?
23k 22 9 14
Hello @miguel.costa and @Mehdi,
Sorry that you have had such a hard time with this issue report.
Would like to encourage you in the the future to continue using developer forums for discussions and questions centered around Refinitiv API usage.
If you suspect an outage, if your issue is time-sensitive, as a customer, the best and most efficient approach to be informed is to open a support case with Refinitiv Helpdesk Online provising the complete details. Your inquiry will be assigned immediately and investigated in a timely manner.
Would also like to bring to your attention Notifications & Alerts -> Service Alerts section, as an effective way to be informed of any known outages or planned maintenance.
It is working fine right now. But on Oct 8th was an absolute nightmare. and it took you guys 8 days to get back to us. Not delighted at all. I don't think your servers are very good.
it is also working now but no one from support contacted us regarding this issue, we had to wait a full day before being able to retrieve our market data, it was a disaster.
Samer issue on our side. A NIGHTMARE.....Refinitiv, please update on the failure
Same issue here, works fine now and then but currently not able to retrieve data. So not able to rely on the api
23k 22 9 14
Hello @glefur, @eddy_de_groot and all,
Please note, that when you are experiencing an issue that requires urgent intervention, such as a suspected service outage, posting on developer forums is not a good idea.
Especially, adding answers to a question where an answer has been given and accepted as correct (please observe above). Adding your new question, as an answer to an answered and accepted question is not a good idea, it prevents most of the forum members from ever noticing it.
In such case the best approach is:
1. To immediately check Service Alerts _> Eikon Alerts (if your issue is with Eikon Data API responding with errors).
2. If you don't find the relevant outage noted, then open a Support Case to investigate online or call your local Refinitiv Helpdesk number to do the same.
In this case, I have just tried EDAPI (some time have passed) and the results appear to come back without any issues, does it work for you as expected now? (this is not a given, there may be a myriad of differences, the first that comes to my mind, is that I may be in a different region, and the suspected outage you have observed may be limited)
I hope this helps?
@glefur @eddy_de_groot
I can not be sure at this time, as the issue has been resolved according to service alerts, however, if you are in European region, this one looks to have been it:
